Need Help/Advise Re-install '89 150 hp
DjPro
This spring I had to remove my console and in the process needed to remove all of my motor wiring/controls. I took tons of pictures but my camera sh*t the bed and now I'm completely in the dark. To make matters worse I relocated the batteries from the splash well to the console and also relocated the trim tilt black fuse box from the rear starboard gunnel to the console. I installed new battery cables but how do I crimp the connectors on? Any help/advice would be greatly appreciated. Thanks in advance.
rickdb1boat
Re: Need Help/Advise Re-install '89 150 hp
They make crimping tools for the job, but you should be able to use a punch and indent the terminal to the wire...
DjPro
Do I need to soder(sp) it?
