need help again don an frends, carburator
bolo789
hello again just when i thought i was over the hill, ok i will try to keep it short, 1989 merc 5.7L rochester four barrel.<br /><br />i rebuilt the carb in the winter i did not get to try it antil last month.<br /><br />when i crank the engin over it flood the carb like a pipe ****, ok i wait about 45 min before restart the timing was way off so i pull the distributor an put it back in, now i crank again and she start up, went out fishing first day no prob, next day i stop to get gas before i could put in the gas i try to restart, it just crank and crank for about 10 min, then it start.<br />after that it run like a hare but when i stop to fish and try to restart sometime it crank crank before it catch. today i put in some gas, try to put a new coil but the new coil was doing nothing so i put back the old one when it start it throttle fine but when i try to give it gas it start back fire now the tac meter is all over the place but the engine idle fine no shaking, what is wrong do i need a new coil or should i return the carb to the rebuilder guy??? i know this is long but i try to put all the simptom in thanks.
bolo789
Re: need help again don an frends, carburator
one more?? is the coil for points engine, diffrent from electronic iginition??? mines is not point it is electronic.<br /><br />thanks
jeff13601
Does your coil say " use with external resistor "? You should still tell the guy that built the carb that it is overflowing
bolo789
thanks jeff13601 the coil that on it now says mercruiser with some numbers, as i goes on i remember the choke link that connect from the engine block was not hook up so all the time i start the engine the butterfly will allways stay wide open and it feels kinda stuck open now i fix that this morning i connect the little pin to the sensor on the block. but the tack is all over the place , it start great. no more flooding but will not take a rev, backfireing
achris
More fish than mountain goat
bolo,<br /><br />Check that the grounding on the coil, electronics module and dissy are all good. Sounds like you've got some problems in that area. What are the numbers on the coil? are they 392-80557-A2?<br /><br />Chris..............
bolo789
i am off to work right now thanks for the info will follow up later thanks
Don S
Back already Chris? That was a short 8 weeks.<br /><br />Bolo, sounds like you could also have a cracked coil tower or some bad plug wires causing the coil wire to spark to the - terminal of the coil that's causing your tach to jump.<br />With the Thunderbolt ignition, if you have a bad plug wire the spark will jump the coil tower to the other coil connections each time it tries to fire on the cylinder.<br />That could also be your hard starting problem. (Bad coil or wires)
bolo789
thanks don, i am trying to get a new coil i try westmarine today but they have to order it so i will try my marina in the morning, a friend lend me two coil from a v 8 engine and not one of them start the engine, why does some engine carry special coil??? this is the number of the one thats on it right now 392-805570-i also can a auto coil work on this??? i also took back the carb to rebuilder to take a look at it.<br /><br /><br />thanks much
jeff13601
I got my new coil at the local NAPA. After I got it it still wouldnt spark and it ended up being bad points
bolo789
update ok i took the carb back to the guy he open it up and do a complete overhall took it back to the boat and install, same thing it still backfire. it sart fine, and idle fine but when i put it in nutral and start to rev it feel weak like it has no power and then puff backfire i put a new coil same thing puff, now what??? this backfire only start when we try to install a new auto coil could that coil damage the magule in the distributor don s help please now this is big how much wire sopose to connect on the positive side of the coil??
jeff13601
How do your plugs and wires look? How is your timing?
bolo789
thanks jeff the wires i put new last month the plugs was also new but who knows with so much gas that was flooding they might foul out .. guss what i am going back to the boatyard just now to pull those plugs thanks again
bolo789
ok guys i am back and i have good news problem solve. i start the boat and took it over my frend marinea to take a look at his coil wiring and behold two of the wires from the igniter box a purple and i think a gray both was connect to the negative side of the coil, the purple sopose to connect to the hot side but i has both connect to the nagative make the right connection and problem solve.<br /><br /><br />so thanks to everyone who help <br /><br />god bless
Don S
A perfect example of why having a proper service manual will save you a lot of maintenance hours by turning them into boating hours........ If you read the manual.
bolo789
thanks don lol you are so right, i always hear you mention that and man did i feel kinda stupid, whish manual i should get for my engine???? thanks again/ but who need manuals when this great forum is here this is betyter than manual lol any way god bless, i can go catch my 50 lbs striper today
