Saskatoon2005
Master Chief Petty Officer
- Apr 27, 2005
- 810
I have a 1961 Johnson Sea Horse and I need to change the lower unit grease (oil). I read my cheap clymers manual and it says to remove the oil level plug followed by the drain/fill plug. Now here is my problem.<br /><br /> I don't have the lower drain/fill plug. I have a Phillips screw in the lower unit and my cheap manual says Not to remove it because I have the manual shift style and it is where the shift rod connects to it. <br /><br /> I am at a loss for what to do. How do I drain the oil I have. Just to keep you up to snuff...I have the RDS-23 and it is a 40 H.P. outboard. Do I need a suction pump to remove it? Then how do I fill it up again? Please help...
