Need help checking stator
hagman
I have a 94 force 120 and need help checking the the stator and or regulator
lonewolf5347
Re: Need help checking stator
A OHM METER SET TO OHMS X1000.TAKE READING ON HIGH @ LOW SIDE RESISTANCE SHOULD BE GREATER THAN 600 OHMS. GO ACROSS TWO SOLID COLORS @ SOLID COLORS WITH A STRIPE IN THEM. :)
Dan K
Something the dealer won't come right out and tell you is that the original stator in your 120 Force is faulty from the factory. Updated part is red in colour. I found this out a year after my warranty expired. Pick up a manual. Electrical diagnosis is clearly illustrated and easy to follow.
