Need help fast about fuel filter/water separator
Marcq
Hi guys, I'm suppose to be on the water right NOW, change my fuel filter/water separator last night and now can't get gas to go to the engine no mater how much I prime the bulb, what am I missing ?
Marc..
Major Woods
Re: Need help fast about fuel filter/water separator
Sounds like a air leak to me or maybe the bulb is shot.
Gary H NC
If you put the filter on dry without filling it with fuel it can do that.
Marcq
Thanks guys, didn't know you had to fill up the filter first, everything is cool now :D
see you on the water
Thanks, Marc..
dingbat
You're vacuum locked. Pull the fuel line off anywhere after the bulb and then pump the bulb. ;)
Marcq
Well, got stranded a bit, must have a leak somewhere , had to bypass the filter. Can I install the bulb before the filter ?
Marc..
