Need help finding a steering wheel
Hello, newbie on this board. I need some help locating a steering wheel for my 1984 Sea Ray Monaco 207 with 350 Chevy/Mercruiser. It does not use the 3/4 keyway, it uses a 3 bolt hub. Where can a find a steering wheel to fit?<br /><br />Thank you!<br />Don
Re: Need help finding a steering wheel
Boat steering wheels today come in 2 sizes,........<br /><br />3/4" tapered with a key,......<br />And<br />1" tapered with a key............<br /><br />Take your 3 bolt Hub Off,+ See which 1 You Have..............<br /><br /><br />BTW, Welcome to the forums here at iboats.com......
Thank you for the quick reply, I took the steering wheel off and there are three bolts that hold the wheel to the hub. Bear with me but what or where do I look for after I take the steering wheel off to see which keyway it uses?
It's the Diameter of the Shaft, Before the Taper,.. That determines the Size.........<br /><br />Is there a Big Nut, in-between the 3 bolts that hold the wheel on ???<br /><br />If So,.... The Taper is behind the Nut.....<br /><br />If Not,....... You're on Your Own,.... I Don't know What you have.............<br /><br />You'll have to Update the Helm to find a Wheel for it..........
