need help finding part 94 mercury 40hp carb part
Kohl1010
I broke the upper carb bowl fitting for my 94 mercury 4 cylinder, 2 carb. I'm having trouble finding a new or used 1
Here I would solder the broken part back on.------Or drill tap and adapt a screw with hole drilled in it.----Easy fix for me.
mgjtkt
I believe that is the main jet for the upper carb. Start searching the web.
Chris1956
I did not find on on the web. A OB salvage yard is a distinct possibility. Also a plumbing parts store, or even the Home Despot should have a hose barb to threaded adaptor. The question is whether the thread is NPT, and whether that tapered area is needed. You could always drill the hole, if it is necessary.
