need help finding the right parts for a merc 470
sampleofme
so my boss and me tore the motor out yesturday to change my flapper and found out the lower unit needs a complete seal kit and also a few other parts im having trouble finding the right parts my boat is a 1981 bayliner with a 470 merc and here is the serial number off the vauvle cover 5735803 here is a list of what i need thanks alot for the help!!
1. complete seal kit for the lower unit
2. water pump impeller
3. gimbile bearing
4. vaulve cover gasket
5. seal kit for the water pump
Bt Doctur
Re: need help finding the right parts for a merc 470
1 cant find one listed, but there are the shift shaft bushing W/ seal,prop shaft carrier O ring.GLM lists 88020
2 get the full kit Sierra 18-3319 or oem
3 Sierra 18-2100 or oem
4 autoparts store Ford 460 V-8
5 pump in outdrive or circulating impeller on engine ?
sampleofme
the pump that goes in the outdrive we are going to reseal the whole thing and he said i would need one of those! also the 460 is a marine version and i cant get one around here from the parts stores! how do i even tell what kind of outdrive i have?
sampleofme
oh and i guess i meant the seal kit for the water pump on the motor i guess the 470's are known for them going out!??
