Need help finding this cover nut tool
Smokepole27
I have a 1987 30hp mariner/yamaha I need to pull the prop shaft due to being bent. I cannot find part number c-91-78729 anywhere if someone could please refrence me Id greatly appreciate it. or if there is a way to make one id appreciate it if someone could help me!
Ryan
verado7
Re: Need help finding this cover nut tool
you can make one out of steel tube or abs plastic or use a screw driver to hammer it out in direction of rotation and replace the cover nut - dealer should be able to get you one though -it's probably under a new part number .
Faztbullet
I do not recommend this as you can bust side of housing. I have replaced several housings that customers broke trying to remove ut this way. The steel tube is a better idea, just get correct size and knotch it with a sawzall..
