HELP ME PLEASE
I lost all my trim pump fluid on my 1986 Century. The pump is model SAE J1171...I refilled it and the trim works again however it is leaking fluid pretty good around the 7/8" large nut towards the top of the pump on the side. There are two of these nuts perpendicular one on each side...What are they for?...I am able to turn out the nut about 3 turns and it gets tight, should I continue to back it out with more force so i can inspect under it?...Is there going to be anything behind this nut that is going to pop out in a certain order that I should be aware of? Any info to get me through this would be appreciated.
