Need help from the yamaha experts!!!
Walidfl
Hi I recently purchased a used 2008 yamaha 90 tlr 2 stroke. A friend gave me an old yamaha tachometer to install on it. He had it on an 87 yamah pro50. Is it possible to connect it to a newer motor. Im not able to attach picture for some reason and will try after I post this question. Unfortunately the colors don't match. The boat has not had guages so I ordered a guage wiring kit 6Y5-83553-N0-00 I know this will connect to the key switch harness and that I will need to run another harness from engine to tach. Im just not sure which harness and if I would need a relay. Any help would be appreciated.
GA_Boater
You have plenty, only need 4 or more. Click on the Forum Help link in the sig below and look at the photo posting tutorial.
Welcome aboard.
Walidfl
Need help intalling an older yamaha tachometer
Hi I recently purchased a used 2008 yamaha 90tlr 2 stroke. A friend gave me an old yamaha tachometer to install on it. He had it on an 87 yamah pro50. Is it possible to connect it to a newer motor. Unfortunately the wire colors don't match I have attached pictures. The boat has not had guages so I ordered a guage wiring kit 6Y5-83553-N0-00 I know this will connect to the key switch harness and that I will need to run another harness from engine to tach. Im just not sure which harness and if I would need a relay. Any help would be appreciated.
