Need help identifying fault code
Toddavid
2014 V-380-C-D, serial A254656.
Threw a code SPN: 266241 FMI: 25
No alarms, engine runs great.
Todd
alldodge
Thanks for all the info, I also have been unable to find the code, hope muc will have better luck
muc
"Retired" Association of Marine Technicians...
Can't find that code either. Where are you getting that code from?
Also noted that your engine is part of a Service Campaign. Time is running out to get this update for free. Suggest you contact a dealer ASAP and also recommend that you get this package registered in your name.
This is Service Campaign 25-2-119
Toddavid
I’m pulling it from the fault memory in my VP Easy Connect.
Regarding the campaign: I’m aware of it, my local dealer blew me off when inquiring about it, said they were too booked to look into it.
The campaign involves temp sensor fitting upgrades. I bought the fittings and o-rings already, cost $20.
What I asked many sources and could not get an answer on (maybe should have asked here): the campaign notes that if the fittings break while being removed, the exhaust elbows might have to be replaced, and my question was who pays for that if that happens?
If there is a high risk of breakage and the related damage is on VP to eat, then it might be worth the effort of getting the boat to the dealer.
If all that VP covers is the upgraded hardware and the labor to replace it, that’s not worth the hassle of lugging the boat to the dealer.
Anyone know how that works?
muc
Are you getting the code from your app or a display on the dash?
Have you updated the software in the easy connect interface?
The campaign bulletin says the risers are covered by Volvo if the dealer ruins them but not if you do.
This is a needed update.
