I recently got a 1961 10 HP Sportwin - this thing is great. It's been idle for a few years, so I replaced the impeller, drained the gear lube, got new plugs and tank tested.
But, after another longer tank test today, I noticed greenish oil floating in the tank. Upon further inspection, I found two drain holes in the lower unit (or at least I think these are drain holes), and a greenish oil is leaking from them, especially after the motor was raised and lowered again.
I haven't drained the gear oil yet.
Assuming this is the gear oil, where should I look for leaks? I haven't replaced any seals while replacing the impeller. I did put some sealant on the mating surfaces of the water pump and the lower unit.
Could use some help. I'm attaching the pictures. Thank you.
