Need help identifying this motor.
ggwash21
Just bought this boat and motor from a buddy, He says its Mid 90's but I think its a 87-88. It doesnt have any plate on the motor for the model number at all. just 15FM01 thats all
F_R
Re: Need help identifying this motor.
Does it have the serial number welsh plug on top of the cylinder block?
watergecko
Its a 89 hood, thats for certain.
ggwash21
J70TLCUR and It comes up as a 87 model, But after looking up NADA 87 says a 2 cyl and this is a 3 cyl?? Anyways
thanks guys. the VRO is disconnected and runs great. Not bad deal for $700 for boat motor and trailer...
Sixmark
Master Chief Petty Officer
NADA is not a source that you use to properly identify a motor, heck I don't even know if I would use their values either.
It is indeed a 1987 70HP and it is supposed to be a 3 cylinder NOT a 2 cylinder as NADA suggests.
Sixmark
P.S. what is all over the transom of that boat, I hope it's not Bondo!!!!
1946Zephyr
Well, if the boat turns out to be junk, at least you got a decent deal on the motor. :D
Nice motor you have there. The 70hps are one of the better 3's built, I think. The design came out in 1968 with the 55hp and mechanically, they were fine, but electronically, they were every repair shop's nightmare. If you got a 65hp from 1970, on, you were okay, but stay away from the earlier ones.
ggwash21
Thats actually the plywood back there, its old and rotten, just not wanting to replace it just yet. I had to repair the hull of the boat still leaks a bit but will hold me over till I find a Nice boat with no motor or trailer. I have yet to run a full tank through the motor she fires right up but I think the carbs need a cleaning.
Also I have a question on my Power trim and tilt. when I trim up it starts slowwwww like the motor isnt at full power, and also if I have it trimmed up and give it gas it pushes down the rams. There is no leaks of fluid any where. Any Ideas?
Sixmark
Sounds like you may have air in the system.
emoney
Make sure there's fluid in there too. Lot's of older trim/tilt systems require rebuilding due to wear and tear and improper maintenance, storage, etc. You may not see any fluid because a lot of it has already leaked out, but it shouldn't be too slow when tilting up. It should go up relatively quick and smooth.
When you answered the question with, "That's the plywood on the back", are you saying that's a plywood repair on your transom, and what's it covering? The question about your transom is because if it's bad, you could find your new-to-you motor on the bottom of the lake (along with the rest of the boat) if the transom were to go. Not to mention the safety of the passengers and crew.
As for the motor itself, you'll grow to love it and don't ever let a Merc guy tell you any different:D
ggwash21
I see what your talking about on the transom, the plywood is fine someone just did a half *** job on paint so it Looks awful... I already ordered from Marine grade ply wood for transom and flooring in the boat.. Had the boat since last weds and Already slamming the Crappies and Lakers :) thanks for the quick responses guys...
emoney
Good for you, nothing like catching 'em out of your own boat is there? Test the flex on the transom to make sure it doesn't move up, down, in or out. If you decide to re-do it, there's tons of threads on here that will walk you through the whole process. It's definitely not something to put off if there's issues.
The sticky at the top of this particular forum (Evinrude/Johnson) has a lot of helpful links inside it. It's from "tashasdaddy" (RIP), but you have to open it to find the specific links. They are labeled so it's really easy to find what you're looking for usually. Tons of great advice on most Johnnyrude issues that can come up.
Sixmark
How in the heck did I miss TD's passing? When did this happen?
1946Zephyr
It was a few months back. You might find the thread in Dockside Chat.
