OK, I'll try to describe this as best I can. My bow eye (the U-Ring that is used to pull the boat onto the trailer) was pulling out a bit so last year I put a steel plate on the backside for more support. Now it's pulling out a bit again because the support "block" is rotted and the plate is being bent a bit in the middle. Basically, there was a piece of wood block maybe 1" thick with lots of fiberglass over it making a block. One side is the outside boat shell the other side is where the nuts hold the eye in.
Anyways, I have dug out the rot mostly and now have a fiberglass shell with the inside having an opening I can get epoxy into, but not easily. I plan to put a few layers of glass and epoxy resin in the "block" area and build it back up as fiberglass. This needs to be done from the inside so it "flows" down into the open area but it's tough to access. I'm trying to figure out how to inject or pour the resin into the fairly small opening in a difficult to reach area. I considered using soup size cans but what would be great is a big plastic syringe with a curved fitting to push the resin in with.
Is there such a thing that can hold up to the heat of the epoxy resin curing without melting? Would I use it and then just set it aside to melt when the epoxy cures? I've had epoxy in a plastic cup before - burned through as I was trying to use it - lesson learned.
I'm sure as long as I mostly fill the cavity with epoxy resin then put the steel plate back on it will be very solid. Any help is greatley appreciated as i am trying to get the boat back in the water for Father's Day weekend!
