Re: Need help locating special axel hub assembly.
Well, you're not quite correct, there. There was one trailer manufacturer back in the 1960s who produced trailers with 3.5" long hubs. The axles had shorter stubs than standard. Can't remember the name, but that was the problem I had. The standard hubs simply couldn't be used, since the threads on the stub simply weren't long enough.
It took me quite a while to find and purchase the right hubs. Northern Tool was of no use whatsoever in this search, since all they offer in 1" axle hubs are for 4" long stubs.
The right hubs are hard to find (I don't have the trailer, or the web site any longer) but worked just fine, since they were designed for that axle.
And...they only came in 5-bolt pattern, so I had to buy new wheels and tires. Not a big deal, since wheel/tire combos are pretty cheap at Northern Tool.
Oh, yeah...the bearings in those hubs weren't the standard stuff, either. Fortunately, the place that sold the hubs sold them only with the proper bearings...all preassembled and lubed.
About $50 each, if I recall correctly.
