need help on a 1989 25ph evinrude tracker motor
sumizzel1999
i have a 1989 25ph evinrude tracker motor.....it is not geting any fire....what should i do to find out why its not getting fire ....it tuning over but not firing up......the motor was not fired up for about 7 years i think....so if any one can help me to tell me what to do or know a web site that got video how to check out the problem or tell me what to check and how to check it thanks
Cofe
Re: need help on a 1989 25ph evinrude tracker motor
Here is a link to the top secret file. Read awakening a sleeping motor,and there are also many trouble shooting guides there..... Welcome to iboats!
sumizzel1999
ok thanks if i have any more ? ill let u know
sumizzel1999
i need the torque specs for the flywheel net .....i have a 1989 25ph evinrude tracker
Cofe
The manual says 100-105 ft.lbs. or 135-140 Nm
Sorry I forgot to paste the link on my previous post. Looks like you found it...:)
sumizzel1999
i need to talk to some one about my motor my number is 574-780-8736 or i can call u give me your number
sumizzel1999
dose my 1989 25ph eninrude tracker have points on it if it dose where are them it not right under the flywheel ......here is my mod # te25elceb and here is the ser # r08234297
sumizzel1999
ok i pop off the flywheel and clean the rust off in side the flywheel and there is a little strip of metal on the back of the power pack assembly that was rusted to and i clean that to and i put the flywheel back on.......and im still not getting no spark.....what can i check and how can i check please give me details how to check and fix the problem.....or if the a video out there to tell me step by step how check and fix that will be cool......because i do not know what im doing .....thank for that help me so far
jasper60103
OK, if I didn't have spark on either cable. I would first check the ground wire on the power pack and both coils. You'll need a cheap multimeter to check this. Also, verify no loose connections to the coils and power pack.
sumizzel1999
ok dose any one has a color wire diagram for the motor and the controls for a 1989 evinrude tracker 25ph the mod. # te25elceb to tell me where every thing go
sumizzel1999
how do i test the power pack and the ignition coil do i need someone to crank over the motor or do i tune the key on or what do i do ...and what do i tune the multimeter at and what numbers should it show when good or bad
sumizzel1999
i want to thanks every one oh help me out i found the problem thanks .......
jasper60103
Would you mind sharing what the problem was?
sumizzel1999
the problem was that i did not know there is a kill switch that u have to pull out to start it ...my old boat motor was a 1967 evinrude 90 hp ...and my new boat motor is a 1989 ...so i didn't know .....p.s i need to know how adjust the carburetor when im putting it back together ...the motor is a 1989 evinrude tracker 25 hp the model # is te25elceb
sumizzel1999
i got 2 ? 1.is are my spark plugs when i take them out are they suppost to be wet or dry.........2.i have a electric primer system and there is a red manual vale..... is the point of the vale suppost to face the front of the boat or back of the boat
