Not a pro here in the least, but ...
I'm just tired of dealing with temperamental carburetors, especially when going to high altitude lakes like Tahoe.
You don't say where you normally are.
Do you often switch between low altitude and high altitude lakes?
Depending on the change, the jetting could be wrong, mixtures etc...
Just as a thought..
Would it be feasible to set up a carb(s) for the low altitude and have a second set for the high altitude?
That way, you could have a good setup or lower altitude, and another for higher altitude..
Maybe it's just a set of jets and you do the swap based on altitude..
Again, I'm NO pro...
It's just a thought that occurred to me when reading this.
Not sure it'd be worth it, but I'm guessing you and the others might know where I'm heading with this, and can guide you better if such a thing is worthwhile..
Edit: Sacramento is about what? 32' above sea level, and Carson City on the other side of the lake is 4,802' above sea level..
With Tahoe being at 6,224' above sea level, there may be changes needed...
Maybe I'm way off base with this, and I apologize if so..
Again.. Just thoughts..
For what it's worth..
