I've got a 17.5' Aluminum boat with a 2003 90HP Merc. It currently has a 13x19 prop. I've just added a bow mount trolling motor and battery. My WOT RPMs have dropped from about 5300 to about 5200 at the trim level I like to ride at.
This is with two adults on board. So I'm concerned about WOT with 2 more adults.
The manual states a 5000-5500 RPM range, with preference in the higher end. Is it worth getting a 13 1/4x17 prop to get the RPMS up a little? I'm afraid a 17" prop is going to put me slightly over 5500 RPM.
If a 17" prop does put me over 5500 RPM at WOT with my load, will I be hurting the motor if I keep the throttle below 5500, or will I be doing the opposite of lugging at that point?
I'm assuming that if a 17" goes over 5500, I can trim down at WOT to safely drop it below/to 5500?
Thanks for any help...I have read the prop selection FAQ.
