Need help on torsion arm replacement on a Ranger Trail trailer
Dobbin
Wheel bearing went out while traveling a distance. Bearings are gone spindle is scared and unrepairable Looking to replace the complete arm and hub assemble including the hub. Found a few but trying to make sure I get the right one HELP
ahicks
My focus would be on replacing the entire axle, and most likely would be purchased hub to hub/complete. They aren't that expensive, and there is no worry over somebody's patch job holding up.
Dobbin
The ends is splined and goes on the end of the axel and is held on by a bolt. the splined end complete with new sendal bearings and hub is what I am looking for
