I have a 1998 Triton Tr-17 that I just recently bought. It has both a recirculating pump and an aerator pump. Neither were working when I bought it, noticed the fuses were both blown, replaced them (confirmed 10amp needeD), and as soon as I flipped the switches, they both blew again.
I figured the most common issues is the pump motors seize up so I changed out both motors. The aerator pump now works and didn't blow its fuse, but the recirculating pump did blow its fuse again, after just being on a few seconds.
Thoughts on next most likely problem? Any guidance on how to diagnose and fix would be appreciated.
I will note that I am testing the pumps out of the water, just making sure I hear the pump running. I know if you run without water, it can overheat over time, but shouldn't blow a fuse after just a few seconds of running with no water, right?
New to the forum so thanks in advance for help here!
