Re: Need Help Please!!
not without testing but surely it will be either stator ,trigger , switchbox , ignition ground , rectifier .
most common sudden no spark problems are switchbox failures .
you need a multimeter with dva adapter - iboats sells both so does CDI electronics.
dont just throw on a new part without doing a thorough test because a failing stator will knock out a switchbox at least every season or more - so will voltage on the ground line going to the switchbox .
if your willing to get the tools - post back .
