Need help removing cylinder head
ImperialV184
I am trying to remove the cylinder head form my mercruiser 165. All bolts are out ,side form one that is so rusted that it has actually become part of the head, I cannot even see the separation. the 3/4 nut is rusted down to about .5 inches but i cannot grip it. I thought about taking a cutoff tool to cut off the top, i am going to replace the head anyway i am pretty sure. this will lev the rest of the bolt in the head, i am concerned i will not be able to get it out. I have heard folks weld new nuts on top, i do not have a welder and would have to take the engine to a shop. will runs don and take a picture. open to suggestions
ImperialV184
Here are some pictures
Re: Need help removing cylinder head
Ayuh,... That bolt head looks like it's been brazed....Welded solid.....
grind it off, 'n Hope fer the best...
ImperialV184
Got it!!! Not sure I am happy what I see after removing the head. Thoughts?
ENSIGN
Have the head and manifold pressure tested you have to find the cause of the water intrusion
