Hi i need to change the dog clutch on my 1986 johnson lower unit… so i pull out the bearing carrier the 2 snap ring and the bearing and plate but now the reverse gear wont come out! it suppose to be easy but it seem to get stuck on the prop shaft… i push the gear and it turn free on the shaft but won’t fall out… do you have any tricks or idea on how to remove it … until i remove it i can’t remove te pignon gear nut and the drive shaft so the prop shaft would not come out …thanks for your help
