Need help to identify this Alpha drive
crazy charlie
Hi guys, I have an Alpha drive available to me and the seller does not have any info on it except this # B412447. I have not been able to find anything based on this # that the seller gave me.Anyone have info that can help??? Thanks guys, Let me know. Charlie
Scott06
I would say that is probably an earlier MC1 which is a bolt in swap With an alpha one. Giveaway will be the lifting eye on top of the drive
can you post pictures?
you need to make sure it is the right ratio for your application. Can remove the top cover to see
crazy charlie
Its a typical alpha one looking drive.Not an MC1 or a gen 2 .I know it is a simple bolt on matchup for my needs BUT not knowing what engine it was mated up to is a problem that I dont want to find out the hard way. Charlie
crazy charlie
Your serial number belongs to a 1986 MERCRUISER MC1 1.98:1, Model number 01989016 stern drive.
Thanks,the year span looks correct to me compared to the alphas I currently have 1988.. The ratio is not gonna work since I have aV8s .I was under the assumption that an MC1 drive was what is called a pre Alpha with the lifting eye on the top of the upper.?? This drive def does not have that. What engine is a 1;98 for??? Thanks again Charlie
Scott06
yes was off on serial number . 1.98 is for a 3.0 4 cylinder . V8 will take a 1.47 or 1.62 ratio.
