Eastboundndown
- Apr 21, 2017
- 74
Hello all, I have 350 Chevy/ with alpha 1. I have a Merc. 2bbl carb with edelbrock intake mnfld & what appears to be an automotive distributor and accel coil. Standard cap, coil is separate. I have an electric choke on carb with 1 lead coming off + side of coil and a second lead which apparently to be grounded to block. I have tried to adjust the 1 air/fuel mix screw on carburetor and have tried messing with the breaker screw on distributor as well as turning distributor itself and I can’t seem to get anything to work. Sometimes it would start at a nice idle for a couple seconds then rev right up. Any thoughts or help troubleshooting would be greatly appreciated. The electric choke and coil are getting extremely hot so I’m not sure if it could be a wiring issue or bad choke?
