Need help troubleshooting
tteal
Symptoms (I'll try to desribe the best way I can):<br /><br />Engine runs good, however, it appears that the batteries are not charging back up (I'm assuming that the 85 Force 125) that I have has an alternator or some mechanism to charge batteries?<br /><br />Anyway, the batteries (I have 2 batteries) are not charging and the tach is not working. <br /><br />I looked through the manual (Clymer) but couldn't find the answer and the only thing that I found that might be the cause of this weirdness is the "Rectifier/Regulator?"<br /><br />Could the rectifier/regulator cause the batteries not to charge and also cause the tach to not work?<br /><br />More info:<br /><br />The wiring on the tach looks correct and the light on the tach works. <br /><br />Any help would be greatly appreciated.<br /><br />If it is indeed the rectifier/regulator, where could I get one and how hard is it to install?<br /><br />Thank you!
roscoe
Re: Need help troubleshooting
Sure sounds like a regulator/rectifier.<br />Tach troubles are typical of regulator failure.<br /><br />You will find the one you need listed half way down this page, only $16. The one for my 95 70 hp is $110!!!!<br /><br /> http://www.outboardparts.com/chrysler/mall/chryslerforceregulators.htm <br /><br /> http://www.outboardparts.com/chrysler/mall/dynamic-results2.asp <br /><br />Pretty simple to install. Unhook the old one, hook up the new one. Just make sure you label the wires so you don't hook them up wrong. Wrap a piece of masking tape around each one, and label them.
tteal
roscoe,<br /> Thank you very much for your help. I ordered a new rectifier/regulator today and will post up my results later.
