Need help. trying to find controls for a center console.
frobotz
Ok so normal boat controls have the shifter lever on the left side of the control for mounting to the side of the boat. I am looking for controls to mount to the outside of my console so the shift lever cant be on the left side of the control box. if it helps I am mounting a 25 merc on a aluminum center console. thanks.
64osby
Use the "normal or standard controls. They get mounted backwards. Pretty sure the cable attachment is reversed inside the controls.
I push mine forward to go forward but the label is showing reverse.
Clear as mud.
merc850
This control box can be mounted on either side and from the bottom
