I've been going round and round with test light and multi-meter trying to figure this out.
I have a Mercruiser 2.5 installed in a Glasstream 170 Malibu with Alpha 1 sterndrive. I am getting no spark to the plugs.
I have purchased and fully charged a good marine battery and installed a new starter ( old one was froze up ) carefully replaced corroded cable ends and connectors and reconnected them one at a time in the right places so I have a good electrical connection where it's needed. When I turn the ignition to the on position with shifter in neutral position, I have spark at the coil on both positive and negative connections. I have spark at the points, the distributor rotates and points open and close. The cap is not cracked nor is the rotor damaged. The point gap is correct. Yet I have nothing going to the plugs. I have changed coil wire to distributor cap with same results. I have even replaced the coil with two other known good ones ( tested all three with multimeter). I have checked wiring for breaks, none, bad connections, none, and juice and all seems to be in order. What am I missing? Why is there no spark to the plugs ( gaps are correct ) ? Any ideas?
