Need help wiring Mercury outboard
agrant40475
Hello all! I'm needing help wiring my 02 Mercury 90 ELPTO stroke. I am replacing a Nissan 50 2 stroke. I will be using the original binnacle controls. I have searched end on end to find an adapter from the Nissan boat side wiring to the Mercury outboard but I am unable to o find anything. Do I need to hardwire it? If so, could someone give me a wiring diagram for the Mercury and Nissan? Thanks in advance!
Chris1956
Gee, are the shift and throttle controls compatible? If you don't know, you should find out.
Wiring can be adapted, I would think. A new Merc boat harness should be able to be connected (likely solder or butt joints) to the control.
Not sure if an adapter harness exists.
