Help Please!!
I will try to make a long story short. Some friends of mine, a couple, purchsed a Bayliner Capri ck lx new in 2000. It has a 5.0. Merc alpha drive. They only used the boat for two seasons. At the end of the last season the boat was winterized and wrapped in heat shrink. The boat has less than 30 hours on it, and has sat for at least two years. That winter the husband suffered a stroke and is now confined to a nursing home. The wife would like to sell the boat and asked me to take a look at it, since she knows I am a boater. I myself own a Mariah but know nothing about Bayliner. I went over and found the heat shrink had caved in and was filled with water. So I started the process of bailing out the water before it leaked into the **** pit, and cleaning the boat. after cleaning and waxing the boat I went to start it and that's when i ran into problems. I had to replace the battery. When I turned the key on, I got a high pitched alarm. Is there some kind of security system on this boat that i should know about? ( I don't have an owners manual) I was able to get the boat started, but I can't keep it running. The boat will not idle. As soon as pull the throttle back to the neutral position the boat stalls and the alarm goes off again. Also I'm not getting a tach reading. The engine will only run with the throttle pushed about a third forward. Since I'm not getting a tach reading I have no idea what RPM it takes to keep it running. What am I doing wrong? Any ideas?
Thanks for any help or info you can provide.
Mike
I posted this on the Bayliner thread, but didn't get much of a response.
Mike
