I have a 1998 Bayliner Capri 1950. I am having a parasitic draw and am having a difficult time locating the problem. I started by removing each fuse one at a time, but no success. Then I came back to the alternator and removed the purple/red wire and noticed the draw went away. I bought a new alternator, hooked it up and once again I have the same parasitic draw. Next I went to the starter and noticed that if I removed the purple/red wire it stopped the parasitic draw. I assume this is because it cut power off to everything on the purple/red line. I also removed the pur/red line from the starter solenoid relay, but the draw remained. Any ideas for what I can check next?
I have attached the wiring diagram of my boat for reference.
