Re: need help with dt 140 exuast
With your outboard jet, the exhaust exits through a tube placed in the middle of the water column that shoots out the back of your pump. When you are on plane, your exhaust exits above the surface of the water making it much louder than a prop which exits underwater. If noise has become a bigger priority than shallow water running, you might want to trade for a 4 stroke prop. That being said, if I get passed by a objet with 6ft of flexible tubing and a Midas muffler sporting hydrofoils, I'll know that it's you.
