I have a 20Ft CC Alumacraft. right around September time frame all electronic accessories stopped working i.e bilge, live well, horn, nav lights etc. first thing I did was clean up the Ground - battery terminal. them cleaned up + terminal and charged battery. after that still no electronics.
I then used a VOM and checked power from battery to first connection on switch panel and I have a severe power drop approx. 5-6V. I thought this was a little High for only about a 6-8ft run of wire.
while working with my brother (electrician in the USCG) he is perplexed at this issue, as the "TYPICAL WIRING DIAGRAM" in the owners manual doesn't look anything like how the dealership wired the boat up.
Now that I have gotten all of you folks just as confused as I am here is another cake topper for you, the other day while hooking up to the boat to go duck hunting I turned my switches on to just may hope and pray it fixed it self my courtesy light on the side of the console was on but VERY VERY dim and still not livewell or bilge pup or nav lights.
Any help in this matter would be great I am about one step away from pulling the main hot and ground out and putting new in?
P.s. I am original owner
