Hi there, welcome to iboats and you're in the correct sub-forum to post this Mercruiser question.:thumb:
When searching for Mercruiser parts it's always best to have/provide your engine serial number to help locate the right parts and help reduce any guess work of if it will fit your engine, stern drive or transom assembly applications should there be any changes.
That mentioned, I believe I found your flywheel part number by year but it seems to be no longer available....The OEM part number is
222-9518 which now would become the starting point to finding another one which probably would be a "used" one such as this one,
https://www.nlamarine.com/products/...3lx-alpha-one-262cid-85-93?variant=1110579788
The flywheel is item number 6 under the parts guide that ought to be for your engine year range but again engine serial number is always best to be for sure,
https://www.mercruiserparts.com/bam/subassembly/31478/951/190
Search the OEM part number online for others if desired.
https://www.mercruiserparts.com/4-3l-2-bbl-gm-262-v-6-1988-1992-0b7
That mentioned, should the flywheel ring gear teeth be damaged, you could also search out say online for a new 1990 Mercruiser V6 flywheel "Ring Gear" to install vs buying the whole flywheel....It takes heat to change out the ring gear though.
Hope this helps, good luck.
