Need help with interior walls. open deck 16 ft tri hull
divco13
Replaced floor and stringer on a 16' tri hall
The inside surface where the carpet doesn't cover,
needs refreshing.
The walls are vertical, non traffic areas.
The side surface's are textured from the factory.
Can it be resprayed with Tinted Gelcoat ?
What do you recommend for Durable and reasonable coast ?
Thanks ahead of time for the help.
Bob P
divco13
Being new to the group. It say i must post at least 3 topic, before I can attach Photos !
Drb007
I don't think you have to post 3 topics, just three posts. You should have that now. Try the pictures again.
divco13
No Title
photo239522.jpg Also had to resize Pictures
alldodge
Suggest something like marcopoxy, which is a two part epoxy paint (white or gray) and just roll or brush it on
divco13
Wood is coated with Polyester thinned with Styrene, allowing it to soak
in to the wood
divco13
Yes two layer of 2 oz mat, one layer of cloth between them. The under side has a layer of 2oz, stynene thinned soak coat first then the 2oz.
Topped with Gel coat, then covered with Marine carpet
alldodge
I would suggest using epoxy paint over using gel, much easier and looks great, pretty sure what is on their now is epoxy paint
