Need help with Johnson stinger J75TRLCSA PT/T
lonron
I just bought my first boat and the previous owner said The outboard needed one of the trim cap seals replaced and he had bought the kit to do it. I don't know which one needs to be replaced as it just leaks fluid out of the manual pressure relief screw and not out the seals. It doesn't build enough pressure to even move the rams. Although the manual pressure relief screw leaks trim fluid whenever I move the motor or try to trim/tilt it (I've tried to tighten and loosen it and fluid output doesn't change much). The previous owner used the screw to lift the motor up and down and I read it shouldn't leak? I order a Yamaha trim cap tool after I broke the one from my local west marine today.
I'm a young kid any information or guide would help.
