Need help with Land and Sea Torque Shift prop
Jamcat137
Hoping someone can help me..... My father, who was an avid boater, passed away a couple of years ago and when cleaning out his garage I found a Land and Sea torque shift/auto pitch prop. I know nothing about props, but it looks like it was barely used, if at all. From the research I've done online, these props are no longer made, but they seem to get great reviews. I have no use for it and would like to sell it on ebay, but I need to know what info to provide. How do I know what type of motor it will fit on (it has 15 splines)? Do they come in different sizes, and if so, how do I measure it correctly? Do I need to know the pitch range? What would be a fair price to ask? Any advice would be greatly appreciated!
steelespike
Re: Need help with Land and Sea Torque Shift prop
You might watch ebay these props seem to a appear regularly there are 2 listed now $400 and $450.
It will help if you can find some numbers. Count the splines look for pitch numbers measure diameter.
measure from center of the bore to the tip of a blade and double.
Jamcat137
Thanks for the tips!
dirktoesup
Need to know what cams Prop must be disassembled and letter is in inside cup area of cam(ie.ZZ,Z,X,W,) are in the blades and need to know the numbers on the prop hub (should be a small group ending in either 32 or 26
