need help with prop
xtremeg35
how it going. i have a 1991 sunbird corsair 198 cuddy cabin with an omc 3.0 4 cly 130 hp. currently i am running a 14.5 x 19 three blade cupped prop aluminum. i am not shure or the gearing and the prop was the one that came with the boat. my problem is that if i have two or more people the boat will not plane or break 13 mph(gps speed) and will not go above 2600 rpm. but if i am alone the boat picks rite up and goes about 25 mph at about 3400 rpm and thats it it wont go any more. . the recomended rpm is 4000-4400. if i down size down pitch would the boat be better.should i try a 4 blade maybe a s\s im stuck and dont know what to try next. i use the boat for tubing skiing cruising. thank you
rndn
Re: need help with prop
It looks like something is not running right or you have a boat that is underpowered. For every 1 inch change in pitch, rpm's change by 200. So if you were to drop to a 14 inch pitched prop (5 inch reduction) your rpm's should get near 4400. (5 inch change=1000 rpm's)
I want to make sure you realize that these numbers are approximate and are only valid for the same prop design from the same manufacturer.
rndn
I didn't notice this was your first post, so...........
Welcome to the forum!!:):)
tysonnathan
19 seems high for that boat.... try going down. call around and see if you can find a place that will let you test run some props... maybe 14 or 15...
