biglurr54
- Feb 14, 2011
- 234
I have a 1989 18ft Crestliner Phantom that has a weak transom. I have been using it but the motor has a little play and now I am noticing that when i throttle up the motor moves down which leads me to believe that the transom is getting weaker. My plan is to take the motor off and take all the bolts and fittings off the transom. Then I will cut where the wood is that needs to be replaced with a angle grinder. Ill remove the sheet of alluminum and that will expose the wood. Then I will either use pt plywood west systemed together or west system in pt dimensional lumber. Im not sure which is the best due to the wood shrinking when it seasons. Then I will take the boat to the local aluminum welder and fabricator and have him weld the sheet back on the back of the boat. I may have him add a few knee braces to help distribute the load.
Does this sound like a good plan of attack?
What should I do for wood in the transom?
