Need Help with Transom Trim Replacement
ERock82
I am in the process of removing my old outboard so I can repower with a new one. My plastic transom trim is badly cracked and I would like to replace it. I have looked online to find a replacement for my particular boat but no luck. It curves up on each side so using aluminum pieces from Home Depot won't work.
The boat is a 14' Bayliner 1401 LS
Is transom trim even needed?
Also, I am attaching a couple links to something I was thinking could maybe work:
1.) Flexible White Vinyl sheet that I would custom cut and screw on with 5200.
http://www.eplastics.com/Plastic/Vin...t/VINWHTPM-020
2.) Rubber garage door seal from Home Depot (just need to find this in white)
http://www.homedepot.com/p/Clopay-18...9067/203921465
Let me know what you think about these ideas. I can't afford to have a plastic mold made from my old trim.
Another thought is to use the aluminum from HD for a straight piece only on the center and where it curves up there would just be nothing. I could gel coat over that part to make it look proper or place the vinyl over that area.
Any advice is appreciated but I am on a budget and don't have tools to bend metal or plastics into shape.
Thanks.
jbcurt00
A pix of what you've got now would help
