skippervan
- Jul 7, 2025
- 3
I have a 1976 85hp Evinrude outboard. The trim was added by the person who gifted me the boat and motor. I don't know what trim motor it is. No numbers or anything on it. It has 2 wires coming from it. Blue (up) and Green (down) The wires to the relays were rusted and just in bad shape. The relays were bad too. Like a dummy I didn't pay attention when I removed the wires from the relays. I did some research on how to wire the trim but I have some across several ways to do it. I just want to make sure I get it correct. This is what I have come up with:
two 5 Pin relays
Pin 30- Green or Blue wires going directly to the trim motor
Pin 87A- Black (ground) coming from battery then jumped to Pin 85
Pin 87- Red (positive) coming from battery
Pin 86- Green or Blue going to toggle switch
Red (positive) wire go to toggle switch from battery
I want to use a 3 way toggle switch (on-off-on)
It was never wired into the control box where the throttle is. I really don't want to mess with it so that's why I want to use a 3 way toggle switch.
Will this work ?
Any advice will be appreciated !
Thanks !
two 5 Pin relays
Will this work ?
Thanks !
