Re: Need help with what this part does.
I use only 650 cca or larger deep cycle dual purpose batteries, but I am 6 miles out in the ocean sometimes and I don't like risk at all. If you look at a map of eastern Cape Cod you will see that we are already 40 miles off the general line of the East Coast so when I say 6 miles, you have to interpret a little.
If you are going to use the battery strictly for starting, use a starting battery. If you like a lot of accessories, or, say, use your trim a lot, you will probably find the starting battery won't last very long because it cannot take the heavy discharge/recharge cycles like deep cycle batteries can.
The longest lasting battery I ever had was a big dual purpose marine battery that I bought at Walmart. Edit: [thanks jay_merrill and see below] it was yellow.
