need help
brian86224
1995 225 johnson oceanrunner tach wont work not charging replaced the reg/rec today with new one still got the same problem what else should i try/check? On the old reg/rec the 2 yellow wires were burnt the jackets wre burned off the wires were still intact what causes this and could that be my problem?:confused: tested the red wire coming from the reg/rec going to the starter solnoid and got .2 volts is this the way to test and does it mean the stater is bad?
muskrat
Re: need help
get a service manual & a meter & do the tests for the stator..
