need help
ncfisherman
I have 98 19' sprint with a 200 on it,I weigh 165# and my cousin weighs 265# went to the lake today and could not get it up on plane can anyone tell me how to adjust my jackplate to give me more take off power also it is a manual
Thanks
Chris
BaileysBoat
Re: need help
Should have no problem. Are you new to this boat?
If it was ok before something has changed, new prop ?
The cavitation plate should be an inch or so above the keel.
BaileysBoat
Re: need help
Should have no problem getting on plane unless the boat is heavy (waterlogged), over propped, or engine performance issue. Have you got it trimmed in when you take off?
ncfisherman
Re: need help
yes I trimm the boat all the way down my motor was adjusted in the middle of the jack plate I moved the motor down about 2 inches will this help?
ncfisherman
Re: need help
top speed is around 70 mph with me and my wife my weight is around 165 and she weighs around 160 I hope that lowering the motor on the jack plate will help me get out of the water faster
BaileysBoat
Re: need help
cav plate an inch above keel as stated. Is the bow high?
kenmyfam
Re: need help
Are you saying that with you and the wife which equals a 100lb less load than you and your cousin that your boat will do 70mph yet it will not plane with you and your cousin aboard ????
Or am I missing something here ????
kenmyfam
Re: need help
Post some photos of your set up, especially the motor, bottom of the hull and cavitation plate.
How much other weight are you carrying and where are you carrying it ??
Have you weighed the outfit to see if you are hauling water sodden foam ??
