Need help !
shiftdtlb42
i have a 1982 mercruiser 470 inboard which turns over and wont start. I bought a new battery, new ignition, new spark plugs, new condensor, points, rotor button. Now its getting spark and i put gas in the carb and it still wont spit or sputter. I just bought the boat and it has been sitting for 5 years but ran perfect before sat. Can anyone please help me with the problem?
shiftdtlb42
can anyone please help me
Re: Need help !
Ayuh,... Welcome Aboard,...
shiftdtlb42
Re: Need help !
hey man hows it going?
shiftdtlb42
Re: Need help !
ive tried carb and choke cleaner also but its not even acting like its gonna crank it just turns over
Don S
Re: Need help !
Not sure what is going on here, but I merged your 2 posts together. One had your problem, the other (the ones with answers) only said ZZZZ. Now we have lots of your posts.
shiftdtlb42
Re: Need help !
alright well thanks haha i just registered for this and im kinda new to boats
bucnon75
Re: Need help !
Just my two cents:
Timing could be way off. Check for fuel smell on plugs to verify it's getting fuel.
Also, check kill switch. Not sure whether you'd have a spark with it engaged.
Before anything else I'd go this link (troubleshooting your engine) in the adults section of this forum:
http://forums.iboats.com/showthread.php?t=167035
Re: Need help !
1982 mercruiser 470
Ayuh,... Do a search of this forum for "470".....
You'll be readin' for Weeks...
full stringer
Re: Need help !
either your points are not set right or the timing is way off an engine only requires 3 things to run spark, air, and fuel one of these is a missing link double check coil and points after checking timing
