Firemedic724
- Apr 27, 2010
- 36
I have a 30 foot Rinker with twin 4.3 Litre MPI Smart Engines. Got a 2 beep per minute alarm when underway. RPM Above 4000 sends the starboard engine into guardian mode with reduction of power to 90%. The engine serial number is OM367129 V-6 262 . Had engine scanned, ghost codes came up. All cleared. The only code that keeps coming up is the over rev alarm. We noticed while underway the Throttle position goes into neutral. Cable and TPS switch adjusted. Went out again and still get the 2 beep per minute alarm then full alarm when 4000RPM is reached. Switched TPS from port to starboard and still the same issue. Everything is good on the dash no issues with oil, water temp, or batt voltage. Sea water pressure is perfect. Has anyone ever have this issue?
