Need ignition wiring help
tom2
Hi,<br />I changed over from a 1984 85 Hp Chrysler to a 1976 105 Hp chrysler. Is the ignition wiring different between these two motors. motor will crank but I have no spark.<br />Thanks for the help,Tom
Laddies
Banned
Re: Need ignition wiring help
If is a 85 hp it should be a Force my book only shows chryslers as 80s unfortunatly Rapair lists, 1 system for force 2 for 80 hp Chryler in 1984 and 2 systems for 1976 105 chrysler, so we need to know more about the systems If they are both Magna Power it should work the rest gets tougher--Bob
WillyBWright
The 85 and 105 wiring would be different regarding the ignition systems. What a suprise, eh? The 85 grounds out the ignition system to kill the motor. The 105 provides battery voltage to the amplifier and it kills when that power is shut off.
chrysler_joe
If the 85hp has a belt driven distributor then it is a batery ignition.<br />If the 105 has a belt driven dist. the wiring should be the same or it may be a mag type two system which has four seperate coils on the outside of the cyl head.
