need info on jensen radio
alldodge
Re: need info on jensen radio
Haven't seen it before but every year they make things smaller. Figure it should work just fine and has a warranty. External connections come from external cables connected from the back side of the unit (I guess due to no front connections). 40W per channel will not give you that much sound but would be good enough for me. Still most time FM is hard to get on a lake due to line of sight. O have a full up system and use MP3 and such because FM keeps cutting out. Also remember you need an external antenna, which can be tapped off a VHF antenna, but not that great
dannys2004glastron175mx
Thanks AllDodge . I think I will get one in the future , I will hook it up and try it out before I cut any holes in the dash. :)
