Need Livingston Repair Suggestions
WN2712NJ
We just acquired a very cheap, very used 10ft Livingston (a twin hulled fiberglass dinghy very popular in these parts). It has a couple of areas needing fiberglass repairs, and I'm looking for suggestions on materials,techniques, etc.
Thanks in advance,
-dm
Re: Need Livingston Repair Suggestions
Ayuh,.... Everything you need to know is covered, over, 'n over, in the Restoration forum....
Hop on down there, 'n start readin'......
Woodonglass
First off Welcome to iBoats!
Second, Pics would really help us to help you.
Hard to know what you're dealin with if we can't SEE it!
Check out my signature line for an easy method of posting pics
I'm just sayin...:D
ondarvr
These boats have very thin hulls and the keel will wear through quickly if they get beached very often.
Read up on doing fiberglass here on iboats, you will most likely have more questions after that, so ask away.
On mine I put down several more layers of glass along the keel of each hull for added strength and wear resistance.
